Newbee - Issues with first print
Synint
Post by Synint »
I have had this printer since last Christmas and not been able to get it printing properly so any help to get it up and running would be very much appreciated.
I have a Geeetech Pro X which I have just changed the temperature sensor to remove the error message on the Lcd which now works. I then try to get my first print off which is a gyroscope key ring using the SD card and the print head makes the print movement but no filament comes out. I then connect printer to my laptop and send stl file to the printer using Cura see link below for the image of print. Also the extruder seems like it's clicking as if the filament is stuck. Any thoughts on what I am doing wrong would be appreciated.
Link to photo: http://ishootimages.tumblr.com/image/167202998321
Re: Newbee - Issues with first print
You should refer to this link:
viewtopic.php?f=19&t=17097
Synint
Post by Synint »
Thank you
