config.ini
colin.eamens@c-eamens.wales
config.ini
Post by colin.eamens@c-eamens.wales »
I have finaly finishing building my Rostock 301 3D Printer and am in the process of setting it to start my first print. following the Manual i have levelled the Hot bed and am now on the set up the slicer softeare.
It mentions loading a Rostock 301 PLA config .ini file.
Where do i find this also will i need to load a ABS config.ini file as well
I am going to try with ABS first
Re: config.ini
ABS is sensitive to temperature, so I do not recommend that you start your journey with ABS printing
Re: config.ini
Thank you, I have also bought some PLA so will take your advice and try thhat first.
Do you know where to find the Config file mentioned in the user manual.
Re: config.ini
It is my own Rostock 301
Rostock301.zip
(1.59 KiB) Downloaded 700 times
config.ini
Re: config.ini
I think you can use Repetier-Host for slicing
