Firmware for Pro W
Firmware for Pro W
good day
I have a Pro W with the current firmware 1.03 and would like to equip it with a capacitive sensor. Unfortunately, I need a firmware> 1.04, I would have to modify this myself, because unfortunately I find no newer firmware with Googel. Therefore, the question of whether someone has already done this and if so, could this person provide it?
Re: Firmware for Pro W
You can download the Marlin1.1.8 for prob firmware at forum
This would I have to adjust for the Pro W yet? Am a complete newcomer and therefore I know myself in the config files not good.
Have adapted the software for the Pro W and would like to share it for others in the forum.
Marlin 1.1.7
Printer Pro W with capacitive sensor
[url=https://www.joehl.org/share/Marlin-1.1.8_2.zip]Download ProW Firmware[/url]
The Sensorkit have i from:
[url=http://3d-proto.de/index.php?p=tips_autobed#Autobed]Distributor for Sensor in Germany[/url]
Mounting for sensor:
[url=https://www.thingiverse.com/thing:1760712]Mounting to print out[/url]
Marlin 1.1.7
Thanks!That is great info!
I have a Pro W with the Geeetech 3D-Touch installed, as opposed to a capacitive sensor. What changes would I need to make to this firmware please.
You should refer to 3dtouch user manual at first
Then you should change the configuration.h and pins.h file
(Don't forget to change the pin value of Servo0 to 11)
[quote=JustinSB post_id=82564 time=1518454915 user_id=62140]
[/quote]
If the board is GT2560A+, an example configuration is provided in the official Marlin repo, branch 'bugfix-1.1.x'. Yo do not need to modify pins.h anymore, just set the board to 'BOARD_GT2560_REV_A_PLUS'. See viewtopic.php?p=82486#p82439
Note that those configurations expect the sensor to be connected to Z_MAX, as opposed to the recommended setup by Geeetech. Please, read both the readme and viewtopic.php?f=27&t=18263&start=280#p82546.
[/quote]
How can I amend this for having no Capacitive or 3dTouch sensor?
You can download the Marlin firmware 1.1.8 and change some value then upload it to your printersonesh wrote: Wed Mar 07, 2018 3:35 am How can I amend this for having no Capacitive or 3dTouch sensor?
