HI,
I am new to the forum and I do not have much experience with 3d printer. About a month ago I acquired an M201, so far I could not perform printing tests because the temperature of the extruder did not rise, always being at 0 ° C.
Can someone help me?
Temperature of the extruder
Re: Temperature of the extruder
I think you should refer to this post
viewtopic.php?f=19&t=18285&p=33459
Hello
I am also new and I also bought M201. constructions I assembled by myself.
For me, the heater works as it should. Check carefully how you assembled the wires.
Because maybe you could be wrong somewhere.
Below the link from the assembly process,
some photos may be helpful.
https://imgur.com/a/PFZU4
In addition, move your hand carefully to the heater to check that it is hot.
It may be that the heater works, and the temperature measurement does not work.
Cool!Thanks for you sharing!_kaktus_ wrote: Sat Jan 20, 2018 7:58 pm In addition, move your hand carefully to the heater to check that it is hot.
