firmware .bin for m201
arakenlotufo
Post by arakenlotufo »
Does anyone have the firmware of the i3 m201 version 1.0.5 in bin format or have the correct hex file installation instruction that does not corrupt the lcd printer system
Re: firmware .bin for m201
arakenlotufo wrote: Sat Jan 27, 2018 4:38 am Does anyone have the firmware of the i3 m201 version 1.0.5 in bin format or have the correct hex file installation instruction that does not corrupt the lcd printer system
Have you tried to confirm your mainboard?
DarkSylver
Post by DarkSylver »
Hi.
I also need it, my board came without the Firmware and when installed it does not work (The LCD is blank). Seller say I must use a .bin file
@William, can you give more info?
Regards
You can use the easypint3d to upload the firmware to your mainboard
Gentlemen, to our great printer model - M201 - the last developed firmware has the number 1.0.03
It contains some errors, which does not interfere with the proper functioning of the printer.
some Errors appear not often but are annoying, others spoil the image of this good product.
The topic about the new version of the firmware is written imprecisely.
We're talking about software v 1.0.05 for our model but in reference to the old version of the controller board.
The current model of the controller board is GTM32 Pro vB - please check what you have.
1 How to burn the bootloader for GTM32 Pro VB board
https://www.geeetech.com/forum/viewtopi ... 20&t=60384
2. How to burn the firmware for GTM32 Pro VB
viewtopic.php?f=20&t=60425
William advised great and wonderful: the firmware can also be uploaded using the easy print application.
Good luck.
In my opinion, you chose the best printer model. ;-D
I would like and wish them all - customers who bought this expensive trinket - gem
so that we can see the revision of this model,
that the patches to contain many improvements and fix known bugs,
this machine has a very large potential due to its functionality and ease of modification.
But I think the producer is not aware of his product.
_kaktus_ wrote: Thu Mar 15, 2018 12:10 am I would like and wish them all - customers who bought this expensive trinket - gem
I think if this product replace the mainboard with RUMBA/RAMPS1.4/GT2560A+
More people will want to this printer
In my opinion,open source mainboard is stronger than the closed one(To customer)
William, you're right, but only partially.
If the manufacturer takes care of his product, it is the best that can meet every customer.
And believe me that no open soure product will be better.
Everything in the hands of the producer.
In this way, the brand is built.
Geeetech manufactures things well, but forgets about their development and improvement.
Then clients suffer.
This is how a very bad opinion is built. Then it's hard to get rid of it.
The company may have problems ...
DarkSylver
[quote=William post_id=83145 time=1521013040 user_id=51382]
[/quote]
Basically ...
EasyPrint3D > Update this new firmware > "Time out" error...
DarkSylver wrote: Fri Mar 16, 2018 7:20 am
William wrote: Wed Mar 14, 2018 3:37 pm You can use the easypint3d to upload the firmware to your mainboard
Basically ...
Could you show us your software version info
You should ensure the Easyprint3d version is V1.1.7
