Voice Recognition Module kits microphone RS232 TTL Converter Arduino Compatible
felixx
Post by felixx »
I bought in ebay
today I received the kit, I need technical support
I tried to run the tutorial in this link:
http://www.geeetech.com/wiki/index.php/ ... le#Example
and this
http://mertarduinotutorial.blogspot.it/ ... -your.html
I connect everything as required, the red LED on the TTL module is on steady, the red LED on the other board flashes continuously
I connect the USB to TTL module to the PC to detect the com port
I use windows 10 ... the system detects the connection of the device to the com5 but with an error "Can not start the device. (Code 10) - A non-existent device was specified."
configuring accessport, the device is not detected
What should I do to get it detected by the computer?
in the pdf manual it does not specify anything
I await instructions or tutorials for the operation
thank you
felixx
Re: Voice Recognition Module kits microphone RS232 TTL Converter Arduino Compatible
Post by felixx »
NO ONE CAN HELP ME?
...so I only lose money!
...false advertise!
...bad product!
...no support!
It is weekend time for me.I will reply you on Monday
