No fans working, low voltage after schottky
pauldgroot
Post by pauldgroot »
Since today none of the fans on my i3 Pro C work anymore. (PWM and the 3 fixed outputs)
After measuring around I found out that the voltage after the 1n5819 diode at D17 (Vin reference point) is just 2,5V, on the input of the diode the voltage is 11,75V which equals VDC. Changing the PWM output switches the PWM output from 0-2,5V. Please help me solve this issue.
https://imgur.com/a/fnDGT (D17 at the right of the image)
Re: No fans working, low voltage after schottky
Sees not same with GT2560A+
