Geeetech i3 Prusa Pro B fans don't work
molekuul
Post by molekuul »
I just build my Geeetech i3 Prusa Pro B, it came with two 2 wire fans, however they don't work. Both fans have 3 pin connector, with only the red and black wire connected. I connected the fans at Fan1 for the extruder, and Fan3 for the boardcooling fan.
What can I do to get these fans working as they should?
Kind regards,
Joris Weijters
Re: Geeetech i3 Prusa Pro B fans don't work
I think you should replace the "Q5"--- AP2306AGN
molekuul
Post by molekuul »
Hi Wiliam,
I thought from the schematic Q5 is only for the PWM Fan
not for the 12volt fans.
Kind regards
Joris
molekuul
Post by molekuul »
I measured the output of the 7812, ther is no power at the output.
There is 12Volt at the input of the 7812.
This normaly means, it's defective, or there is a short circuit behind this 7812.
What is behind the the 7812? Other than the Fans?
Kind regards,
Joris Weijters
molekuul
Post by molekuul »
Hi William,
I found the problem. There was an short circuit between the + and the - of fan3!
see picture below
https://i.imgur.com/wcmbzEV.jpg
I insert the jumper, now my fans work
I removed Q4 and the 7812
I still don't know what Q4 is needed for.
Kind regards,
Joris Weijters
Q4 is for
No matter PSU is 24V or 12V
The output interface of fan voltage is 12V also
