Stepper mottor not working on Delta G2s
Hi, I have a problem with the x stepper mottor. It won't move up properly just jerks around in its place. I adjusted the tension on the belt, no help, also switched the x motor connection to the y motor and that one started to jerk and stay in its place. I double checked all the board connections, there is something definitely wrong on the board. Anybody had this problem before?
Re: Stepper mottor not working on Delta G2s
And did you try to regulate the current for the stepper motor?
I think you can increase the voltage of motor driver board A4988
You can refer to this post
