Hello I just finished my printer and when I swicht it on nothing is hapening. I´ve put together once a BQ i3 and turning on it went to 0 the X,Y,Z screen was on and so on.
This printer is not doing anything at all.
Has it got firware out of the box? it does not?
Please help
Startup ProW
Re: Startup ProW
Could you upload a video of this issue to Google drive?
I need more details to help you
Re: Startup ProW
Hello William;
After a searching in the web I have found the mistake.
All issues are talking about swap de lcd and sd cables!
Ok, but being european kept me puting the cables allways in the right position respecting the plastic holder.
Well, the answer was:
FORCING THE F.CK.NG CABLES WRONG INTO THE SOCKETS!!!
Not SWAP, but TURN the conector and force it to fit!
Now I´m happy waiting for my third print to finifsh.
Re: Startup ProW
Thanks for your feedback! I will tell them if others encountered the same issueIsoweb wrote: Fri Mar 23, 2018 6:19 pm Hello William;
Re: Startup ProW
Are You serious, was that the resolution, because I thought that was B.S.?
rjorthmann
rjorthmann
Re: Startup ProW
The main menu/Index lists me "rjorthmann" as the author of the forum post, but it is not.
Thank you
rjorthmann
Thank you
rjorthmann
Re: Startup ProW
I'm from "euro" and I never had to turn the connector round and force it to fit into the housing, looks like someone sold you a dodgy printer/ LCD controller ( I saw a video on YT of someone doing what you said after they got an LCD clone, I think it was)
