Two-color printing configuration
gpau
Post by gpau »
How do I set up the printer for two-color printing at both the software and hardware level?
I currently use the new firmware for the Geeetech i3 Pro C.
I have not been able to print in two colors yet.
Thank you
Re: Two-color printing configuration
You need to select dual extruder at your printing setting
gpau
Post by gpau »
that ok, but what settings should I put
gpau
Post by gpau »
this fact, but what settings should I put in the program?
You need to refer to this user manual at first
gpau
Post by gpau »
Do you have a repetier-host configuration for the i3 Pro C?
Thank you
You can refer it
PRO C.rar
(1.31 KiB) Downloaded 1090 times
BR365
Post by BR365 »
I didn't understand, how to configure and calibrate the dual extruder on our I3 C Pro printer, nor how to select, which extruder should be used for which part.
Furthermore, I can't find a possibility, to move the extruder to a specific x-y-coordinate. E.g. I would like to set for Extruder 1, go to x:100, y:100
Then, I do the same for extruder 2 and I would be able to calculate the offset.
Is there a manual or manpage available, to follow step by step?
Thanks,
Moritz
