Does this geeetech gt2560 board have any unused pins that I can control 12v ledstrip?
Right now I just activated extruder 2 and soldered led strip to it and it works. But I would like to script it to change colour with temperature.
I've looked through the pins.h file and nomatter what I change or try, the pins dosent seem to change. example I tried chaning extuder 1 pins to extruder 2 pins and 2-1 and still, the extruder 1 had old pins. From pins.h I changed the pins where it was "board ultimaker"
Another question can I use drv8825 stepper driver with this board and what do I have to change?
gt2560 pins
Re: gt2560 pins
1.DRV8825
you need to change the driver micro stepping>Refer to this
https://www.pololu.com/product/2133
2.You can use the pin "7" of the PWM fan interface(5~12V)
