I have just assembled the y-axis rods and bars. I then discover that the assembly video shows that there is a difference with the centre spring washer. On one bar it is on the left of the connecting fender and on the other it is on the right hand side.
In the Word document instructions, it 'hints' that both of these should be on the right hand side, like in the attached picture.
Which is correct, please?
David
Y axis Rods
Y axis Rods
- bar.png (199.28 KiB) Viewed 4576 times
Re: Y axis Rods
Proceed intuitively and treat the assembly instructions as a hint.
Whatever you do, and so it will be fine.
Head up and forward. ;-)
