Good day
I‘m using a PI3 Pro C with SWVer 1.0.04 (Dual Extruder) with RepetierHost 2.0.5.
Manual control via repetier Host is functioning, but when heating up EXT1 (Temp Set 200°C) the temperature is rising above 214°C and then the LCD shows ERR: MINTEMP and on RepetierHost screen the following message: Error: printer stopped due to errors. Fix the error and use M999 to restart (Temperature is reset. Set it after...)
Extruder 2 is working perfectly (same settings for both Extruder)
Any idea or solution?
Extruder1 temperature control
- 6410F091-F792-4EE8-A45D-6917FAB732EA.jpeg (976.67 KiB) Viewed 3948 times
- 2D1D6D81-45AC-42A6-B6C6-247B0BEF9E8E.jpeg (463.58 KiB) Viewed 3948 times
