Good day
I‘m using a PI3 Pro C with SWVer 1.0.04 (Dual Extruder) with RepetierHost 2.0.5.
Manual control via repetier Host is functioning, but when heating up EXT1 (Temp Set 200°C) the temperature is rising above 214°C and then the LCD shows ERR: MINTEMP and on RepetierHost screen the following message: Error: printer stopped due to errors. Fix the error and use M999 to restart (Temperature is reset. Set it after...)
Any idea or solution?
Extruder 1 temperature control
- 7DCA50CD-E551-485F-9070-B7DA9C48A7BB.jpeg (976.67 KiB) Viewed 4246 times
- 1C6F93FA-2430-4014-A117-1B08D0D38BA9.jpeg (463.58 KiB) Viewed 4246 times
