rostock 301
rostock 301
how do i adjust the motor voltage
Re: rostock 301
Look at this picture from another post.
download/file.php?id=1512&sid=ed25eedb5 ... 9b1f1f594f
You will need to adjust the potentiometer which is the silver colored, screw with a cross in it. It is labeled with a +. You will need a voltmeter.
Re: rostock 301
Welcome to Geeetech world.
You can easily search lots of message from this forum.
Make full use of search function, sometimes you might get the answer immediately.
Re: rostock 301
thank you very easy to do, i thought it would be a software item, i will give this a try. do you think this will get them to run in the correct direction? every time i have tried to run it the head just shoots to the plate.
Re: rostock 301
okay, i now have all my pots running at 1.1v all my motors are running in the correct direction, but i think i got some bad linear bearings. reason i think this, they do not glide smoothly like the rest of my other printers. they all feel like they might be scoring the riser shafts, how can i get this problem taken care of?
