attached is my working Marlin 1.1.8 configuration.h with BL Touch working if you would like to use.
Please feel free to use or suggest any improvements.
I have the Z axis anti wobble installed. The BL touch works great for the most part but I am struggling with the Z offset when I change or maintain the head. I store the Z Offset in the EEPROM which allows me flexibility with changing the offset on the fly i needed.
[attachment=0]Configuration.zip[/attachment]
BL Touch Working Configuration
- Configuration.zip
- Configuration.H Changes with BL Touch
- (22.02 KiB) Downloaded 807 times
Re: BL Touch Working Configuration
Thanks for sharing!! :D
My savior! Will try this ASAP. Thanks for sharing!
Printer: Geeetech Prusa I3 Pro W
Firmware: Marlin 1.1.8 with BLTouch
Well, I have used this Configuration and works very well, but I still can't find a more finer configuration to print with the quality advertised with almost everyody that uses an auto bedleveling device.
This are my prints of the same filament between the various prinst that I have tested
https://drive.google.com/file/d/1ElRHd0 ... p=drivesdk
https://drive.google.com/file/d/1X7L3Qt ... p=drivesdk
Your configuration with the Marlin 1.1.8 version with BL Touch shows goshting in my print, and the older Marlin 1.0.4 with the BL Touch prints well, but not as good as when I use the vanilla Marlin 1.0.4 version provided by Geeetech and having to manually level the bed.
So, as for me, I will stick with this old version in the meantime as it works well for me anyways.
EDIT: Corrected the images links. Sorry for not correcting it before
I think you can have everything at once.
But there is a long way to go with adjusting the work parameters.
