How do you unload filament?
SoupersSB
Post by SoupersSB »
I am running low on filament and I want to print something big so it would be best to use my new filament. How do I unload the filament from the printer without using any computer program (Using the settings on the printer)???
Re: How do you unload filament?
Use the options from the Preheat PLA or Preheat ABS printer menus. Next Move 10mm -> Move Z, until the whole filament is pulled out.
:mrgreen:
PaulB
Post by PaulB »
Use the preheat PLA option, press the extruder lever down and smoothly remove the filament. Cut the tip off before you use it again.
Feeding the new filament in is a reversal, preheat, press the lever down and feed the filament in.
SoupersSB
Post by SoupersSB »
_kaktus_ wrote: Mon Jun 11, 2018 12:39 pm Use the options from the Preheat PLA or Preheat ABS printer menus. Next Move 10mm -> Move Z, until the whole filament is pulled out.
:mrgreen:
I don't have the option to move Z, only X and Y
Well, you can see, I wrote Z by distraction, and I was referring to the Extruder (E). :oops:
I need to be more careful.
I have this possibility in my printer.
Also refer to the Move 1mm option.
SoupersSB
Post by SoupersSB »
_kaktus_ wrote: Thu Jun 14, 2018 12:19 pm Well, you can see, I wrote Z by distraction, and I was referring to the Extruder (E). :oops:
I don't have E either
In this case, after heating up the head, the filament must be pulled out manually.
SoupersSB
Post by SoupersSB »
_kaktus_ wrote: Fri Jun 15, 2018 11:49 am In this case, after heating up the head, the filament must be pulled out manually.
Do you even have an i3 pro b? I cant just pull it out! it doesn't come out!
No, I only have one model.
And I really wanted to help you, as you can see I didn't succeed. ;)
If there is really a big problem with removing the filament after the head has warmed up, you may need to open it up.
Perhaps @Gingko will come up with something better. It has access to all models.
Gingko
Post by Gingko »
Usually, heat up the extruder to 200C, then press the lever, the filament can be pulled out (or push in a little, when melted then pull out).
@Kaktus is right, if it's still hard to do that, try to take off the fan, heat sink and check inside, take pictures if possible.
