Power Supply Problem
kavsnzre
Post by kavsnzre »
Hi all,
I just mounted the printer, following the pdf and video instructions. But when I try to switch on the printer, the current turn at my home.
But my wiring scheme is exactly the same as the one shown into the instructions! Please, could you help me to understand the problem?
I attach the photos.
The PSU:
The ON/OFF:
When i put the plug into the wall the ON/OFF switch lights (even if it is OFF!):
If I try to swith ON, the current goes down, everywhere in my home (the green light of the PSU turn ON for a while).
Please help me, best regards,
Michele
Re: Power Supply Problem
Symptoms appear to be an installation error. But if you have connected everything correctly, it can be a sign of a damaged power supply.
