It says the E180 has Wifi
inkwizitiv
Post by inkwizitiv »
It says the E180 has Wifi printer but mine is greyed out as in pic
Re: It says the E180 has Wifi
clipping
clipping
Gingko
Post by Gingko »
Recently the inner WiFi module has been cancelled for some modifying, it can just use the external 3D wifi module, so may I ask that where do you read that message?
The information might wrong and should be updated.
3D WIFI.jpg (14.88 KiB) Viewed 11515 times
rogerio53
Post by rogerio53 »
it is said in the user manual i downloaded in jun.26.
i usually download user manual before buying to know better the product.
Gingko
Post by Gingko »
rogerio53 wrote: Tue Jul 10, 2018 5:01 pm it is said in the user manual i downloaded in jun.26.
From which website?
Check four documents attached here:
https://www.geeetech.com/geeetech-e180- ... -1026.html
but find no wifi function introduction...
If you can point out and help us correct that, we will be appreciated. :)
rogerio53
Post by rogerio53 »
