Hi to all,
I try to start my first print with I3B but I got some trouble. I tried to load my sample to the printer but set temperature are not loaded and printer doesn't start.
Any help?
Thanks in advanced.
First print problem
First print problem
- IMG_20180715_122338.jpg (211.33 KiB) Viewed 4981 times
Re: First print problem
Which software do you use?
Have you tried to make a head movement from the slicer panel?
Did you print through SD card or USB?
Can you directly set temperature through LCD or slicer software?
I use the one installed, no software upgrade is done.
I connect the printer via USB.
No I'm not able to move the extruder by slicer
What can I do?
What can I do?
