Hi guys, I'm new in the field of 3d printing, recently I have ordered a prusa i3 pro b and after 2 days building and setting up the machine, this morning as a reward there were two lines of rectangles on the LCD.
I started immediately looking for a solution and I've seen almost all the posts on how to fix this problem, nothing worked until now.
( I'm working over a MacBook Pro with High Sierra, my board is a GT2560 rev A+)
- I've tried to update the firmware but ( either with arduino 1.0.1 or latest build ) the response was a beautiful "avrdude: stk500v2_ReceiveMessage(): timeout"
- At this point I switched over a Windows 7 machine, worse, the Arduino software did not recognise the board through USB. I tried to install a series of drivers but still nothing. ( The led on the board connected to Windows USB lighted up less than normal )
- Then I took my arduino Uno and tried to burn the bootloader but still an error ( either with arduino 1.0.1 or latest build ) : "avrdude: Yikes! Invalid device signature."
I thought there was a easy fix but seems like things are getting more complicated, I really need some help.
Can some component be broken ?
How can I fix It ?
All the help even the stupidest would be appreciated.
Thanks guys.
GT2560 failing fw update and bootload burning
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
