Retraction Not working properly after latest firmware upgrade
steveski21
Post by steveski21 »
I issue i have is after the lastest firmware was installed on my A30
now when doing a retraction test print it sucks the filament up the teflon tube there for doing a dry print
How do I fix this ?
Re: Retraction Not working properly after latest firmware upgrade
:mrgreen:
After uploading the firmware update, did you try to use the option: Restore default settings?
steveski21
If you are serious no
is that really what i was meant to do
This option is worth trying.
steveski21
Tried that it did'nt fix it I did how ever work out that the extruder is slipping and it's not related to to low of temp on the hotend
Gingko
Post by Gingko »
Could you please make a short video of "it sucks the filament up the teflon tube there for doing a dry print"?
