Printer stopped working after update.
Cricc0
Post by Cricc0 »
i tried to update the firmware via EasyPrint on pc following the instructions of a tutorial on youtube by Geeetech.
During the process the update stopped with the message:"Update Failed", now the printer is stuck and i can't use it. From the display i can access to everything but the settings panel, so i can't reset the printer to the factory settings. Is there a way to fix it?
Gingko
Re: Printer stopped working after update.
Post by Gingko »
How is your printer now?
You can to use this method to update the firmware:
viewtopic.php?f=20&t=60676&p=82222#p82222
If the display still unnormal, the files in SD card for LCD might broken, you can repair it follow this:
viewtopic.php?f=64&t=60677
Ryan04
Post by Ryan04 »
I fixed it temporally by small welding at mycoles login, but I would like to get a new intact cable on mythdhr login.
Halvorsonnm
Post by Halvorsonnm »
If you're encountering this problem, the easiest fix is to roll back the latest Windows update. To do this, open Settings > Update & Security > Windows Update > View Update History > Uninstall Updates > Uninstall, or remove the patch manually in Command Prompt. Some Reddit users confirmed that this fixed their problem.
official website
Leslie7433
Post by Leslie7433 »
Looking for the same issue. Bumped into your thread. Thanks for creating it. Looking forward for solution. UPSers Login
