LCD data cable? A10
LCD data cable? A10
I just got the A10 printer, I can connect to it via USB and control it but the ribbon was bent so the LCD doesn't light up unless I hold it in a particular way. Does anyone know what kind of cable it is? Can I order another cable from somewhere? I believe the board is a 2560. I've included a picture of it:
DarkTreader
Re: LCD data cable? A10
how many conductors are in that cable? if it is 50 I believe Amazon has it at 200 and 300mm. here is link to 300mm cable
https://www.amazon.com/Forward-Directio ... Flat+Cable
I bought this one with 1.5 meters but there's smaller ones.
https://www.aliexpress.com/item/3288602 ... b90aTym3by
notes:
1) 0.5mm pitch (1mm will be loose)
2) 40 pins
3) FPC FFC (Forward Type A)
I have an A10m
notes:
2) 40 pins
I have an A10m
Imcallumwbu
Hi, I know it’s been a while since you posted, but I bought the same cable as you from aliexpress, but the SD card doesn’t read with it, it only works with the original cable. How did you solve it?
