homing z-axel
Douwe
homing z-axel
Post by Douwe »
When using autohome the z-axel just goes up a bit but not home.
The happened suddenly.
What can I do?
Re: homing z-axel
:mrgreen:
I would try to press the appropriate stepstick into the socket.
Of course, the power supply to the printer must be switched off first.
Gingko
Re: homing z-axel
Post by Gingko »
Douwe wrote: Tue Aug 07, 2018 3:35 pm When using autohome the z-axel just goes up a bit but not home.
What can I do?
It works fine before?
Have you checked the wiring of endstop?
Douwe
Re: homing z-axel
Post by Douwe »
It ok one moment and the next the z-axel only moves up (in homing).
When I manualy want to move the z-axel with the turn button, it can move up and down. So I think the wirering is ok.
Douwe
Re: homing z-axel
Post by Douwe »
I stupid!!!
Ginko, you were right! I overlooked that one wire of the endstop came loose!
Thank you so much for helping!
