How to calibrate e steps?
k40z
Post by k40z »
Hi there!
I need to verify e-steps of my A30.
Where i can find actual e-steps setting?
Thanks a lot,
k40z
Gingko
Re: How to calibrate e steps?
Post by Gingko »
viewtopic.php?f=17&t=60639&p=82054#p82054
Download the motor tool and connect it with your printer, then you can get status or set steps.
sean wrote: Wed Aug 08, 2018 11:18 am https://github.com/Geeetech3D/Smartto-Tool we moved the tools to single project.
We are not suggest that modifing motor parameters now(2018/8/8).Because there are some fatal errors in newest firmware(1.39.62 for A30/1.33.42 for E180) but only these firmwares support PID commands.
We are working on it...
k40z
Re: How to calibrate e steps? [solved]
Post by k40z »
Thank you.
Has worked for me with motor controller.
Regards.
Gingko
Post by Gingko »
_kaktus_ wrote: Wed Aug 08, 2018 3:10 pm
Yes, the PID and some rest commands cannot be used right now, but as for travel speed, step, direction, and velocity are still available.
