Z axis moving slowly
I have just purchased a new board from Geeetech , with the marlin software loaded by Geeetech
The Z axis moves very slow is there anything I can do to speed it up.?
Thanks Jim
Thanks Jim
Re: Z axis moving slowly
Hi, I need some information.
What's your printer type?
Are your Z thread rods M8 or T8 and what is the Z step/mm?
How does it move when printing?
Hi thanks for your reply
The printer is an i3
The rods are m8
Motor step angle 1.8
Driver microstepping 1/16
The motors move very slow and only move around 1.5mm when I ask it to move 10mm
Any help would be appreciated.
Jim
The rods are m8
Jim
I3 is a group of printers. This indication does not represent your model. This is important information.
Jim, your answer is vague.
The Z step/mm value should be 2560, please check the value through LCD->CONTROL->MOTION->Z STEP/MM.
Hi thanks again for you reply.
The printer is a Geeetech i3 Pro B
The board is a GT2560 rev A+
Can you give me the information on how to access the information and correct in easy steps please as I am a amateur to computersso a lot of detail or is there a manual on how to do this
Thanks Jim
Thanks Jim
Issue resolved thanks to advise.
I used Repetier in manual mode and set M92 Z2540
M500 to save
I also found the item on the LCD screen under Control Motion Zaxis steps
Thanks again Jim
M500 to save
Thanks again Jim
You're welcome
Enjoy printing!
Enjoy printing!
