E180 Slic3r Profile Anyone ?
BennyBoyW
Post by BennyBoyW »
Hi All
My E180 appears to be coming on in leaps and bounds.
One thing though - I would like to switch over to Slic3r as opposed to EasyPrint.
I believe I have set up my profile correctly, but stand to be corrected.
The problem is that the printer heats up the nozzle nicely - then beeps 3 times, beeps 3 times again and then homes itself as though it's finished printing. Then the firmware seems to go a bit odd and I have to turn off and on again.
Any ideas anyone ? I've attached my profile as it stands
IniFiles.zip
(2.55 KiB) Downloaded 682 times
kyoday
Re: E180 Slic3r Profile Anyone ?
Post by kyoday »
hi, you solved ?
D-a-n
Post by D-a-n »
Hello!
My working config for Slic3r-1.3.0.64bit
E180_NEW_CONF.zip
(1.64 KiB) Downloaded 759 times
Configured:
- optimal sticking of the part to the tape
- optimal settings for PLA
- optimal layers and part quality
- optimal print speed (medium)
- fill patter Honeycomb (recommend Rectilinear)
Not included:
Spiral vase - set if you want to print a vase, may require additional layers
Print finished G-code through EasyPrint3D!
This instruction and trial and error method helped me:
https://3deshnik.ru/blogs/vestas/slic3r ... ichja-nora
