How to add the printer I3 M201 to Cura
Posted: Fri Aug 31, 2018 4:36 pm
Hi guys! :o
Are you can't find Geeetech M201 on Cura?
Don't worry
Refer to these:
1.Download Cura Profile for M201.zip(the .json file for M201)
(1.74 KiB) Downloaded 1184 times
------------------------------ :D --------------------------------------------------
2. Unzip the zip file then you will get 3 files
3.Copy "Geeetech_M201.def.json" to the
Cura installation directory
Default:
C:\Program Files\Ultimaker Cura 3.1\resources\definitions
4.Copy "Geeetech_M201_extruder_0.def.json" and "Geeetech_M201_extruder_1.def.json"
to"C:\Program Files\Ultimaker Cura 3.1\resources\extruders"
5.Done!Enjoy it!
Re: How to add the printer I3 M201 to Cura
Posted: Fri Aug 31, 2018 6:21 pm
by _kaktus_
Perfectly.
:D
Posted: Thu Jan 31, 2019 6:38 am
by Alexgol_8
Hello, сan you upgrade to Ultimat Сure 4 ? Then he writes that the printer is not connected (visible in the lists of printers, connection via USB). Maybe you need to register the port number and speed? The driver does not have these fields.
For version 2.4 there is such a patch. Can you redo it for version 4?
Posted: Sun Feb 03, 2019 6:16 pm
by _kaktus_
Hello.
Yes, this problem is known to me ...
Have you tried to find a solution on the Cura forum :?:
Posted: Sun Feb 03, 2019 6:45 pm
by Alexgol_8
Posted: Sat Feb 16, 2019 4:19 pm
by algernon
Hello
I had two problems. Diameter of wire in 2.85 to be modified if necessary and it was necessary that I remove the temperature controls M109 it always printed at 200° even after modification.
First impeccable try thanks!
Image; Image
Posted: Thu Dec 24, 2020 8:58 pm
by Ziad
hi have you be able to cura
am having the same issues
