Configuration problem A30 & Cura
Posted: Sat Oct 06, 2018 9:15 pm
by FGL
It doesn't work for me at all (Cura 3.5.0). It's unable to print, like the extruder is not feeding enough plastic, or the Z axis is not close enough to the bed (it's correctly leveled, it works nice with EasyPrint)
Re: Configuration problem A30 & Cura
Posted: Thu Oct 25, 2018 4:10 am
by Sneakers
Yeah, I had the same problem with Geeetech's Cura Profile. I've been using the Cura profile for the CR-10 and it's been working great!
Posted: Thu Oct 25, 2018 6:28 pm
by Miceltu
Look to my experience:
http://www.geeetech.com/forum/viewtopic ... 770#p86812
For your convenience here the important settings:
2018-10-25 12_25_55-Preferences.png (13.1 KiB) Viewed 14577 times
2018-10-25 12_26_41-Machine Settings.png (11.1 KiB) Viewed 14577 times
Posted: Sat Oct 27, 2018 2:08 pm
Please check the fw version of yours(A30)
1.v1.36.57 and later version can work with the mode of USB (Cura)
2.If you can attach the photos then we can refer it
Posted: Sat Oct 27, 2018 4:00 pm
by Miceltu
Imho the issue is, that the the quality is poor. Not the connection.
Posted: Sun Oct 28, 2018 5:35 am
by DaliborBalic
i am very new to all this, had the same problem with Cura+A30, and for me, it was exactly as you said "not enough material" there is parameter called "flow" when i set it to 120 it was much better for me
Posted: Sun Oct 28, 2018 4:09 pm
by anrkii
I tried the official Geetech a30 cura printer settings along with other, and they simply did not work. The initial layer was printing far too high off the bed, even with the Z level calibrated to .05mm with a feeler gauge, and there was severe underextrusion. My Cura printer setting is for the CR10 with the bed size adjusted and I imported a Geetech A10 profile and went from there. I am running 120% flow rates in cura currently. Here is a single walled airplane wing section I just printed today:
The A30 is a decent machine, but the lack of easy firmware upgrades and no usable Cura profiles make it not so great for getting started. This printer really needs better software support.
Posted: Fri Nov 16, 2018 8:32 pm
by SebastianM
Hey anriki,
can you share your a10 cura profile?
I am having the same issues as you (the a10_dog.gcode sample prints fine, but when I slice an object on my own, i have massive underextrusion).
thx!
Posted: Mon Nov 19, 2018 1:26 am
by Miceltu
@SebastianM: Here is the solution for your problem:
https://www.geeetech.com/forum/viewtopi ... 770#p86812
Posted: Wed Mar 06, 2019 9:20 pm
by Just an AI
I know this post is a bit late but can you print over usb like this?
