A30 problem
A30 problem
I received my new Geeetech A30 printer nine weeks ago. After five weeks trying to level the bed, I found that the X axis was out of a line so and to correct the left side Z axis. After printing some test squares that looked great, I tried a print of a Benchy after the 4mm brim had successfully printed the filament stopped coming out of the nozzle and the Bowden tube come out of the extruder and the filament was coiling out of the tube as it was still loading but was not being extruded, after stopping the print I managed to remove the filament But now I cannot even load any filament to the extruder although the nozzle gets hot
Re: A30 problem
It seems to me that you will have to get acquainted with the construction of the head and the extruder.
I suggest to carefully unbolt everything to the first parts and clean.
It has clogged with the filament, and blocked the transport road.
Re: A30 problem
Thanks for your help, I am totally new to 3d printing, but I will check the internet to find how to dismantle the hot end
