Geeetech A30 Cura Profiles
Sneakers
Post by Sneakers »
Hi does anyone have a Cura Profile they would like to share? I saw a reference that there are Cura profiles on facebook but I don't have and don't want facebook :cry:
I found these posts:
A30-Cura-profile https://www.geeetech.com/forum/viewtopic.php?t=60652
How to add the printer Geeetech A30 to Cura: https://www.geeetech.com/forum/viewtopic.php?p=85788
However, they don't print well. Printing the demo files works great. I also get good results in Cura by using the profile for the CR-10.
Re: Geeetech A30 Cura Profiles
Maybe you can refer the attached file
Geeetech A10 CURA3.2.zip
(1.42 KiB) Downloaded 662 times
dogmatic69
Post by dogmatic69 »
I just used the defaults under new and set the table size + marlin g-code. Works fine, not sure why everyone is on about loading a fancy profile...
I've now had a look a the files and there is nothing extra in there.
Your issue is almost certainly slicer issues rather than machine profile. Use the built in PLA settings, I changed bed tep to 80 and print to 200. Printed perfect out the box just like that.
