A30 Source Code for 1.58 firmware??
Thank you for releasing the 1.58 firmware that allows us to add the BLTouch to the A30. However, that version of the source code is not on your Github repository so we are unable to make custom firmware changes to our machines. Can you tell me when that version of the source code will be uploaded to Github?
Re: A30 Source Code for 1.58 firmware??
A very good question, anyway did you tried to create a bin with the source code whats online in github ?
Could you please do a step by step guide ?
Here's the process that worked for me:
1) Download https://www.iar.com/iar-embedded-workbench/ for ARM
2) Install the IAR software. WARNING: It requires registering and getting a temporary license from IAR. The software is not hobbyist focused. Poor decision on Geetech's part to use this tool. Hopefully the momentum picks back up to migrate to Eclipse.
3) Download the Geeetech Smartto-IAR source code https://github.com/Geeetech3D/Smartto-IAR
4) Find the GTM32.eww file in the Project directory of the source code and open it.
5) In the workspaces section of the IDE, right above the source code project hierarchy, make sure you've chosen A30 from the dropdown menu
6)There are files missing from the source code that will prohibit it from compiling so you need to copy files from the IAR directory
Go to this location "C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\src\flashloader\NXP\FlashQN9080\chip_qn908x\cmsis (or wherever your IAR is installed) and copy all the files except the "core_cm0.h" file and paste them back into this folder wherever you downloaded the source code to: "...Smartto-IAR-master\src\STM32F10x_Core\"
7) Once those files have been copied to the source code location, you should be able to right click on the project and select Make and it will compile. You should have a number of warnings, but no error messages. You can ignore the warnings.
8)All changes you need to make should be made in the "Configuration_GTM32_Pro_A30S.h" file which is under the User directory. It has many of the same settings as Marlin 1.1.x
If you get it to compile and need assistance in uploading it to the machine, i can share how i did that also.
Lastly, keep in mind that if you are using a BLTouch, this version of the source code is not going to work. It does work for the proximity sensor however.
Ah okay, i was looking for the eclipse type, bcs they wrot that the IAR version have complications in long term prints.
https://github.com/Geeetech3D/Smartto-Eclipse
Currently they have stopped development on the Eclipse version due to major issues. All of their factory firmwares are running from the IAR version. They have not announced if, or when, they will resume development on the Eclipse version.Lexan wrote: Mon Oct 29, 2018 4:40 am ah okay, i was looking for the eclipse type, bcs they wrot that the IAR version have complications in long term prints
I've followed them on their Gitter channel and it sounds like it's going to be a very long time before they bring out a working Eclipse version.
Also would like to have code of working version, the one at github is pretty obsolete (.61 ver, but older that .58)
Well the good news is that I managed to dump the Lopy firmware so I can erase the flash, experiment with the ESP32 SDK and come back to the MicroPython firmware at any moment. If you don't want to release the schematics then at least a block diagram would be nice to see how everything inside is connected and which pins are what on the header.
andrewpiana
maxhenty4759
- Contact:
Thanks for this informative article, I hope you will get the most positive response especially for this post. . .
target visa gift card balance
target visa balance
target visa card balance
check target visa gift card balance
target visa prepaid card balance
mybalancenow target
check mybalancenow
target visa balance
mybalancenow target
check mybalancenow
locaswatson98
- Contact:
Thanks for sharing the details. I simply wish to let you understand that I really looked into your site and also I found it fascinating and useful.
Sephora Gift Card Balance
Sephora Gift Card Balance Check
Sephora Card Balance
Sephora Check Balance
Check Sephora Gift Card Balance
Sephora Check Gift Card Balance
Sephora Gift Card Check Balance
Check Gift Card Balance Sephora
How to Check Sephora Gift Card Balance
Check Jcpenney Gift Card Balance
Jcpenney Gift Card Balance Check
Sephora Online Gift Card
Sephora Gift Card Online
jcp gift Card Balance
jcpenney Card Balance
