My X-axis motor is not working. When it tries to move, I only get a jittery vibration - without any true rotation in either direction.
I swapped motors and the problem stayed with the x-axis.
I swapped driver boards, and the problem stayed with the x-axis.
So - it's either the main board, or firmware/software issue.
I'm noticing some discoloration on what looks like the capacitor underneath.
Suggestions? Is Geeetech good at sending replacement parts if needed?
help with stepper driver - stuttering motor
- driver_board.JPG (113.52 KiB) Viewed 19322 times
Re: help with stepper driver - stuttering motor
You also try to swap motor cable too?
If it doesn't help either, try to re-upload the firmware.
We provide replacements for free if your printer still under warranty.
Those didn't help. How would I go about getting a new board under warranty then?
You need to contact the sales then tell them about it._shorty_ wrote: Sun Nov 11, 2018 8:25 am Those didn't help. How would I go about getting a new board under warranty then?
