partscooling-fan not working at all
SebastianM
Post by SebastianM »
Good morning from Germany!
Yesterday I received my A10 (new version with filament sensor) and the first print went very good. Unfortunately, my partscooling-fan does not work at all.
Neither when I print the sample gcode (A10_dog.gcode) nor when I set it in the menu to "255" (menu control / temperature / fan).
No reaction from the fan at all...
thx in adavance...
PS: This isnt my first 3d printer, so I know what I am doing :))
Re: partscooling-fan not working at all
:mrgreen:
So, in the first step I would check the correctness of the connections.
The second step is whether there is a voltage on the fan's cables after the fan has been driven.
Check the 12/24V fan type and compare it with the control voltage.
SebastianM
ehm... where exactly are the pins for the parts-fan?
SebastianM
Update: I played a bit with the cables and now it seems to work...
I will keep an eye on it.
thx!
Gingko
Post by Gingko »
Check the slot on the extension board first (seems you got it).
So it might be the poor connection? ;)
Matteo Simioni
Post by Matteo Simioni »
SebastianM wrote: Thu Nov 15, 2018 2:46 pm Good morning from Germany!
thx in adavance...
Hi SebastianM, I am having exactly the same problem with my A10 that arrived few days ago, can you please tell me exactly how you solved?
Thanks very mutch!
SebastianM
mathiaskahn
Post by mathiaskahn »
Exact same problem here, with new A10 (GT2560 v3.0 mainboard).
Proposed solution (play with cable) does not solve.
Any idea ?
SebastianM
I got a replacement Fan...
