Good morning.
I have a problem.
My a30 does not complete the gcode file.
Performs all the printing, but when it arrives at the end of the file is not executed part of the code.
For example: perform the end of heating but the unlocking of the motors is not performed.
I tried to update the firmware but nothing.
Someone can suggest where is the problem?
End code not execute
Re: End code not execute
Can you show the final part of the code with which there are problems
in the last firmware there is the bug that when you print via sd card a mashine set end gcode comes after your slicer end gcode and it looks like smartto would ignore your end gcode
