The printer makes objects 5 times higher
Yoveu
Post by Yoveu »
Good evening, I've assembled the printer and I've made many successful objects, except for one detail: they're 5 times higher than the stl model.
It's precisely 5 times higher, right dimensions in X and Y axis, 3/2 the time supposed by easyprint.
To "fix" the problem I've reduced the files to 1/5 of the original highness, and I obtain what I want..
But: crushing the file I lose many details, so till now I avoid making things that need high resolution.
Do you know what could be the problem?
Re: The printer makes objects 5 times higher
You need to check the rod type of yours
1.For T8 rod ,400 step for it is correct
M8 is 2560
2.Try to replace the A4988 of Z axis :D
Yoveu
Post by Yoveu »
You’re right, it’s a T8 rod (even though the instructions refer to M8 rods and nuts).
Do I need to contact the seller for a substitution or there is a method to tell to Easyprint/the printer that the rod is T and not M?
Thank you for the answer!
:mrgreen:
You need to make the appropriate configuration.
And I know that you don't read the forum.
Yoveu wrote: Sun Nov 25, 2018 1:32 am You’re right, it’s a T8 rod (even though the instructions refer to M8 rods and nuts).
1.Download the firmware
2.Open the configuration.h
find the "#define DEFAULT_AXIS_STEPS_PER_UNIT { 80.3, 80.8, 2560, 93 }"
then you can change the 2560 to 400
Upload the firmware via Arduino 1.0.1
