A10 new firmware
totrebor
A10 new firmware
Post by totrebor »
I upload this firmware http://www.geeetech.com/forum/download/file.php?id=4719 to my A10 with GT2560V3.
Before to upload the printer have no problem to print but now does not work, when the printing start the bed does not move.
If I move the bed manually (from LCD) all run OK.
Someone can help me ?
Roberto
totrebor
Re: A10 new firmware
Post by totrebor »
same problem :(
totrebor
Post by totrebor »
Some other information:
I tried to move Y axis by the LCD manually and it moves, bat if
I try to send a command "G1 Y10 F1200" from repetier it doesn't move.
"G1 Z10 F1200" and "G1 X10 F1200" work without problems.
I hope someone could help me. :( :( :( :(
totrebor
Post by totrebor »
new update:
with G1 X200 the x axis go to 200
with G1 Y200 the y axis does not move (position home)
with G1 Z200 the z axis go to 1.87
totrebor
Post by totrebor »
I already check the wiring and connections, but I dont think that it is an electrical problem because with lcd command all work.
I think you can check the Y axis endstop first:
viewtopic.php?f=17&t=60927
Tell us the result,pls. :D
totrebor
[SOLVED] A10 new firmware
Post by totrebor »
I builded the firmware with arduino IDE 1.8.7 so Z and Y axis not work.
I rebuild the firmware with arduino IDE 1.8.5 and now all work. :o
