TMC2208 Firmware for A30, GTM32miniS/GTM32 PROVD
This is the firmware for TMC2208 for A30 beta version.
Does someone want to try it?
A30_TMC2208 test.zip
(78.21 KiB) Downloaded 938 times
dekes1
Re: TMC2208 Firmware for A30, GTM32miniS/GTM32 PROVD
Post by dekes1 »
I don't have TMC2208s to test at the moment, but for reference, that version of the firmware has been out since October and has worked just fine on multiple A30s.
One side note: the A30 doesnt have the GTM32 Pro vB. It has the GTM32 Mini S. Here is the board in detail: http://www.geeetech.com/wiki/index.php/ ... TM32_Board
dekes1 wrote: Fri Nov 30, 2018 6:25 am I don't have TMC2208s to test at the moment, but for reference, that version of the firmware has been out since October and has worked just fine on multiple A30s.
Sorry,I have correct it.Thanks! :D
anrkii
Post by anrkii »
If I use this firmware, must I replace all of the drivers with the tmc2208? or can I just upgrade the X and Y axis drivers?
anrkii wrote: Sat Dec 01, 2018 7:53 am If I use this firmware, must I replace all of the drivers with the tmc2208? or can I just upgrade the X and Y axis drivers?
You can replace one motor driver board. Others, you can use the A4988. It will work.
GreenEyedExplorer
Post by GreenEyedExplorer »
Hi all. William, your FW update few posts back corrects moving in X and Z axis. The movement in Y axis works too, as it did in officially published V1.58. After updating FW, I only had to change motor directions in the settings. So, thank you, my printer A30 is now silent.
For those interested, I make youtube videos. At the moment I am reviewing and twicking A30 (general review, updates to make it top of the top, some solutions to HW/FW problems etc.). Videos are not sponsored.
Check https://www.youtube.com/channel/UCIOIhh ... LB0azJmd8w
I have years of 3D printing experience. In conclusion, the A30 is the TOP of cheap 3D printers!
The only hope I have is Geeetech will soon do the Marlin migration as Smartto is buggy...
:shock:
And I deeply believe that problems with the Smartto firmware will be resolved definitively.
And this software can be better than Marlin 2.
Unfortunately, all this takes time.
:D
GreenEyedExplorer
Smartto could be way better than Marlin, but it should be made for Arduino. IAR workbench is to expensive for general public to work with. The migration to Arduino would give Geeetech a high number of contrubutors... It is not that hard as it already is in C and may parts of the code are from Marlin. Another problem is the opensource is only mainboard code, not the LCD code. And some odd things come from LCD part.
But this all is just for us programmers. For general public FW/HW already works good...
BTW, Why doesn't external wifi module come with PC program, only android/xphone? Will they release sources?
GreenEyedExplorer wrote: Fri Dec 07, 2018 9:04 pm ...
Good question :!:
david6534
Post by david6534 »
I have have downloaded your tmc2208 Fimware and installed it on my printer. But when i am now auto home my axis all axis will move in the wrong way even though i have switched the direction of the motors. Can some of you help me with this issue?
Thanks for help and sorry for my Bad english i am from Germany :)
