Newbie - 1st Layer Problem
Posted: Sun Dec 02, 2018 5:54 pm
by gerryd646
Hi, Any help would be appreciated,
Newbie (1st Printer) been trying to print this for 6 days.
What I have done:
Leveled, leveled and then leveled and then once more to be sure
Upgraded the firmware
Bought an Adhesion mat
Using Easyprint 3D – Tweaked a few settings from YouTube videos - Think its called "Baconing"
Tried the Cura Software – To no avail.
Re: Newbie - 1st Layer Problem
Posted: Sun Dec 02, 2018 6:46 pm
by _kaktus_
Hello.
Parameters important for the first layer are:
- slower printout,
- increased dosage of filament,
- leveled surface,
You have also paid attention to improving adhesion to the ground.
So you are no longer newbie.
I did not see in the presented configuration a parameter determining material feeding.
What brand of filament do you use?
Have you tried to change the temperature of the hot end
Do you know
this guide?
Posted: Sun Dec 02, 2018 7:20 pm
by gerryd646
Hi Kaktus,
Thank you for the fast reply.
I will try slowing down the first layer.
I have tried 200 - 205 - 210 and 220 for the nozzle temperature.
Not sure which parameter in the settings is "material feeding" the 3 pages I included seem to be the only ones i can adjust - Its EasyPrint 3D and the manual that comes with it doesn't really go into detail about each parameter.
I am using the Geetech 1.75mm PLA filament.
I had seen that guide in my troubleshooting research - Wasn't sure which one was my problem - this seemed the closest -
https://3dprinting.stackexchange.com/qu ... e-bed/3709 and that's when i bought the mat
Regards
Posted: Sun Dec 02, 2018 7:45 pm
by _kaktus_
I read the information from the link you posted.
It is worth doing a few tests.
I don't use PLA, but I reduced the thickness of the first layer, setting it like the rest.
But I have set the filament feeding to 130%
(with a layer thickness of 0.2mm).
Much depends on the quality of the filament.
Posted: Thu Dec 06, 2018 3:28 am
by _kaktus_
Hi.
I am curious about the results of the tests you have carried out.
Posted: Thu Dec 06, 2018 4:29 pm
by gerryd646
Thank you for your help Kaktus,
Changed 1st layer height from 0.3 to 0.2mm
I slowed down the first layer speed to 25mm/s from 30
and the material flow from 250 to 225%
All other settings the same.
And Viola it worked.
Posted: Fri Dec 07, 2018 12:43 am
by _kaktus_
Posted: Tue Feb 23, 2021 3:53 am
by alenaofficial
Compare Lenovo laptops & notebook computers, all engineered with solid security tools & functional design. Free shipping & returns.
https://bestlaptopbudget.com
by alenaofficial
1. Logitech MX Master 3. The best mouse for creatives right now.
https://best-mouse.com DPI: 4,000 | Interface: Bluetooth and 2.4GHz wireless | Buttons ...
Posted: Wed Sep 01, 2021 2:40 pm
by leozop
