Newbie - 1st Layer Problem
gerryd646
Post by gerryd646 »
Hi, Any help would be appreciated,
Newbie (1st Printer) been trying to print this for 6 days.
What I have done:
Leveled, leveled and then leveled and then once more to be sure 😊.
Upgraded the firmware
Bought an Adhesion mat
Using Easyprint 3D – Tweaked a few settings from YouTube videos - Think its called "Baconing"
Tried the Cura Software – To no avail.
settings
settings
Problem settings 1.jpg (135.42 KiB) Viewed 12084 times
settings
settings
Problem settings 2.jpg (129.21 KiB) Viewed 12084 times
settings
settings
Problem settings 3.jpg (152.19 KiB) Viewed 12084 times
Part to be printed
Part to be printed
Problem settings 4.jpg (126.73 KiB) Viewed 12084 times
Part Being Printed
Part Being Printed
Problem settings A.jpg (198.3 KiB) Viewed 12084 times
Close up
Close up
Problem settings B.jpg (295.56 KiB) Viewed 12084 times
Re: Newbie - 1st Layer Problem
:mrgreen:
Parameters important for the first layer are:
  • slower printout,
  • increased dosage of filament,
  • leveled surface,
You have also paid attention to improving adhesion to the ground.
So you are no longer newbie. :D
I did not see in the presented configuration a parameter determining material feeding. :roll:
What brand of filament do you use?
Have you tried to change the temperature of the hot end :?:
Do you know this guide?
gerryd646
Post by gerryd646 »
Hi Kaktus,
Thank you for the fast reply.
I will try slowing down the first layer.
I have tried 200 - 205 - 210 and 220 for the nozzle temperature.
Not sure which parameter in the settings is "material feeding" the 3 pages I included seem to be the only ones i can adjust - Its EasyPrint 3D and the manual that comes with it doesn't really go into detail about each parameter.
I am using the Geetech 1.75mm PLA filament.
I had seen that guide in my troubleshooting research - Wasn't sure which one was my problem - this seemed the closest - https://3dprinting.stackexchange.com/qu ... e-bed/3709 and that's when i bought the mat
Regards
I read the information from the link you posted.
It is worth doing a few tests.
I don't use PLA, but I reduced the thickness of the first layer, setting it like the rest.
But I have set the filament feeding to 130% (with a layer thickness of 0.2mm).
Much depends on the quality of the filament.
Hi.
:mrgreen:
I am curious about the results of the tests you have carried out.
gerryd646
Post by gerryd646 »
Thank you for your help Kaktus,
Changed 1st layer height from 0.3 to 0.2mm
I slowed down the first layer speed to 25mm/s from 30
and the material flow from 250 to 225%
All other settings the same.
And Viola it worked.
:mrgreen:
I am happy about your success :!:
:lol:
alenaofficial
Post by alenaofficial »
Compare Lenovo laptops & notebook computers, all engineered with solid security tools & functional design. Free shipping & returns.
https://bestlaptopbudget.com
alenaofficial
1. Logitech MX Master 3. The best mouse for creatives right now. https://best-mouse.com DPI: 4,000 | Interface: Bluetooth and 2.4GHz wireless | Buttons ...
leozop
Post by leozop »
