Newbie (1st Printer) been trying to print this for 6 days.
What I have done:
Leveled, leveled and then leveled and then once more to be sure .
Upgraded the firmware
Bought an Adhesion mat
Using Easyprint 3D – Tweaked a few settings from YouTube videos - Think its called "Baconing"
Tried the Cura Software – To no avail.
settings
Problem settings 1.jpg (135.42 KiB) Viewed 12090 times
settings
Problem settings 2.jpg (129.21 KiB) Viewed 12090 times
settings
Problem settings 3.jpg (152.19 KiB) Viewed 12090 times
Part to be printed
Problem settings 4.jpg (126.73 KiB) Viewed 12090 times
Part Being Printed
Problem settings A.jpg (198.3 KiB) Viewed 12090 times
Close up
Problem settings B.jpg (295.56 KiB) Viewed 12090 times
You have also paid attention to improving adhesion to the ground.
So you are no longer newbie.
I did not see in the presented configuration a parameter determining material feeding.
What brand of filament do you use?
Have you tried to change the temperature of the hot end
Do you know this guide?
On the forum I help to use the rod, I don't give fish. Geeetech Prusa I3 M201 Dual extruder Mixcolor 3D printer,bought 2017-12-19, already built, in the cognitive and improvement phase Geeetech filament, ABS only Geeetech 3D WiFi Module for 3D Printer, bought 2018-04-15, He got a new life, and still lies in a drawer. Positively frenzied customer of Getech Technology.
I will try slowing down the first layer.
I have tried 200 - 205 - 210 and 220 for the nozzle temperature.
Not sure which parameter in the settings is "material feeding" the 3 pages I included seem to be the only ones i can adjust - Its EasyPrint 3D and the manual that comes with it doesn't really go into detail about each parameter.
I am using the Geetech 1.75mm PLA filament.
I read the information from the link you posted.
It is worth doing a few tests.
I don't use PLA, but I reduced the thickness of the first layer, setting it like the rest.
But I have set the filament feeding to 130% (with a layer thickness of 0.2mm).
Much depends on the quality of the filament.
I am curious about the results of the tests you have carried out.
Changed 1st layer height from 0.3 to 0.2mm
I slowed down the first layer speed to 25mm/s from 30
and the material flow from 250 to 225%
All other settings the same.
1. Logitech MX Master 3. The best mouse for creatives right now. https://best-mouse.com DPI: 4,000 | Interface: Bluetooth and 2.4GHz wireless | Buttons ...
