Aluminum Prusa i3 Memory Issues
wlaswell
Post by wlaswell »
I have the aluminum i3. When I set my value for the zstep/mm, the controller won't keep the value I've set. If I back out of programming, or if I shut off the unit, it just defaults at 2560...
Also, when the unit is on for 4 or 5 minutes, my screen goes garbled. I have to unplug the machine to get it to reset....
I've updated the firmware, but nothing...
2018-12-09 04.04.29.jpg (211.68 KiB) Viewed 14968 times
Re: Aluminum Prusa i3 Memory Issues
:mrgreen:
Can you show a photo of how you laid the cables?
Also the cables to the display module.
1.Try to restart the printer
2.Try to check the wires short circuit or not
Billio
Post by Billio »
I had a garbled screen when the power was off but the USB cable was plugged into the socket and a laptop.
The board GT2560A can use the power of the USB.You can remove it then restart it
