Is there any extension cables set for the A30, similar to the 1 meter set that is commonly available for the CR-10 type printers? I ended up trying a CR-10/CR-10S set that I found on Amazon and while most of the cables are compatible, the filament sensor wire is of course missing and the two larger cables to extend the heated bed wiring and the hot end / print head wiring are not compatible as both of these connectors use a different number of pins than the A30 cables.
Any suggestions, beyond just cutting apart the cable set and soldering in longer wires?
extension cables set for A30?
Re: extension cables set for A30?
In my opinion, it is not a good idea to extend high-current cables.
