A10 filament feeder motor not feeding
marklinoz
Post by marklinoz »
I have a New A10 printer that I received for may Birthday in December.
Everything works EXCEPT the filament feeder , the gear just moves two teeth forward and then two teeth backward and wont feed any filament.
I cannot find any one to help, with what looks like an excellent 3D printer.
I am using standard PLA
https://www.dropbox.com/sh/pr3fs7xikakr ... kuq_a?dl=0
video of the problem
hope some one can help
Fugly
Re: A10 filament feeder motor not feeding
Post by Fugly »
Read this maybe it helps you. sound like the same problem
https://www.3dhubs.com/talk/t/stepper-m ... rth/2513/2
buttervonwaffle
Post by buttervonwaffle »
Honestly my printer had the same issue. The spring tension most likely isn't good enough to feed the filament. The stock spring they send with the printer has the tension of a noodle. I temporarily fixed mine initially with a penny placed in between the spring and the plastic. Basically like a shim. Now this is temporary because eventually it will stop working, cause that plastic is brittle and that spring is going to lose that tension because of the poor spring quality. A more permanent fix is one of these I have seen them cheaper on bang good. But they do a great job of solving the tension issue.
If something I said just helped you out tremendously you can drop a little ramen money, the coding monkeys in my basement will appreciate it - Feed them here
You can private message me if you have any questions I might be able to help.
lenkiely
Post by lenkiely »
I found the same thing, just using the tension screw fixed them both up.
What is ramen money?
