A10 dimensions
Shinobi
A10 dimensions
Post by Shinobi »
Hi guys,
I'm thinking of getting an A10, but I hope you can tell me the exact size the printer needs including the moving built plate and cables. My space is tight and I also want to put it in an enclosure. On Banggood it says the dimensions are:
478mm (left to right?)
413 (front to back?)
485 (bottom to top?)
Is this correct or do I have to add extra space for cables and connectors to that?
Thanks a lot!
Shinobi
Re: A10 dimensions
Post by Shinobi »
Thanks a lot. My only issue is the dimension from front to back. Thats my only real limiter. 20 inches (500mm) is much more than the 413mm in the spec sheet. Weird...
