Geeetech A10 cannot get a firmware in!!!
valentinguz
Post by valentinguz »
Trying to upgrade the firmware it stopped and failed half way in. Now the screen doesn't show anything furthermore EasyPrint does not detect the printer so I cannot use the firmware Upgrador to fix it. Trying to use Arduino Ide to upload a firmware gives me this error:
Code: Select all
Arduino: 1.8.8 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 151620 bytes (59%) of program storage space. Maximum is 253952 bytes.
Global variables use 5402 bytes (65%) of dynamic memory, leaving 2790 bytes for local variables. Maximum is 8192 bytes.
avrdude: stk500v2_getsync(): timeout communicating with programmer
An error occurred while uploading the sketch
How can I fix it and get my printer back to factory settings?
buttervonwaffle
Re: Geeetech A10 cannot get a firmware in!!!
Post by buttervonwaffle »
Did you happen to remove the sd card by chance? If not remove the sd card and then boot it up.
If something I said just helped you out tremendously you can drop a little ramen money, the coding monkeys in my basement will appreciate it - Feed them here
You can private message me if you have any questions I might be able to help.
