Stock Firmware
Daza-C
Stock Firmware
Post by Daza-C »
as nobody has replied to my post im not sure if it is a hardware of software issue.. i am new to 3d printing and feel a bit out of my depth!
i upgraded my firmware to A10 marlin 118 and thats where im having the heating failed issue
so does anyone know where i can find original stock firmware so i can revert back to factory state and reset it so i can start again from fresh as im running out of ideas
Thankyou
buttervonwaffle
Re: Stock Firmware
Post by buttervonwaffle »
Heres a link to stock firmware - marlin 1.1.8
Heres a topic that has in depth troubleshooting for this specific problem as well - temp troubleshooting I know the power supplies on these are very cheap, and have a tendency to crap out but luckily you can get better power supplies for these to alleviate issues.
These are cheap printers so hardware failure isn't out of the realm, and the nice thing is you can upgrade to better parts to reduce the chance of it happening again at the same time expanding the realm of capabilities with said printer.
If something I said just helped you out tremendously you can drop a little ramen money, the coding monkeys in my basement will appreciate it - Feed them here
You can private message me if you have any questions I might be able to help.
Daza-C
Re: Stock Firmware
Post by Daza-C »
Hello
Thankyou for the reply, i will have to look in to that forum post and see if i can spot anything from that.
do you have any recommendations to hardware manufacturer replacements for my A10 if it is faulty like the PSU?
buttervonwaffle
Re: Stock Firmware
This is what I suggest to upgrade to, but do your research and decide what you want. But for 50 bucks you just cant go wrong with a Mean Well power supply. It gives you 350 watts so you definitely will have more than enough power, I think they maybe use at most 160 watts when they are printing so roughly what a graphics card does, so you can probably go lower. But the more robust of a power supply will allow you to upgrade and do more and plus the amazon you can get a nice warranty on the power supply, which is worth it, if your printing 24/7.
