Extruder 2 Slicing Problems- Cura
trixster87
Post by trixster87 »
New owner of the A10m. I'm using Cura 3.6 with the Json files from : http://www.geeetech.com/forum/viewtopic ... ura#p89761
When I slice a model (single or dual color) for extruder 2 the gcode does not call for temp to be set. I have verified that the temp is set for 200c in the slicer profile(standby included).
I know this is slicer related cause when I use the marlin color mixer menu to flip the extruder models sliced for e1 print fine and models sliced for e2 do not. I currently do not have any special start gcodes for either extruders.
theroar84
Re: Extruder 2 Slicing Problems- Cura
Post by theroar84 »
Not quite sure if this is the problem you had. I had a temperature error where it tried to heat tool 1 instead of tool 0 and would freeze. This is how I solved it.
https://youtu.be/PJ8JvSphOE8
trixster87
That link pointed me int the right direction, but there's an easier way if you set it up as a post processing script that cura automatically does.
Add the find and replace post processing script twice. Once to replace M104 T1 with just M104 and M109 T1 with M109
